BVF carbureter setup HELP
Nur die Technik machts ... (Schweißen, Fräsen, etc.). Technische Probleme gehören in den Bereich Tuning oder Allgemein.
Moderator: MOD-TEAM
Antworten
Nachricht
Autor
Wrighty
Fußgänger
Fußgänger
#1 Beitrag von Wrighty » 26 Feb 2018, 22:43
Hello everyone I apologise for me writing English but id like some help with the factory carb settings for my bvf carb on my s51 50cc.
Screw here
And another screw next to choke mechanism
I have played with the screws but it's hopeless with out a base factory setting
Thank you
0 x
Benutzeravatar
Björn Heinze
Schraubergott
Schraubergott
x 1355
x 340
Kontaktdaten:
Re: BVF carbureter setup HELP
#2 Beitrag von Björn Heinze » 27 Feb 2018, 04:29
0 x
Benutzeravatar
dhperformancegarage
Simson-Kenner
Simson-Kenner
x 1029
x 267
#3 Beitrag von dhperformancegarage » 27 Feb 2018, 07:03
When you have a S51, your carb ( 16N3)on the picture is not the right carb.
The right carburetor for s51 is the 16N1-11
0 x
85/2 von eastsideperformance :thumbsup:
70/2 von eastsideperformance :thumbsup:
85/5Membran von Adler tuning :thumbsup:
Simon S93
Simson-Schüler
Simson-Schüler
x 19
x 58
#4 Beitrag von Simon S93 » 27 Feb 2018, 12:14
I cant see the pictures anymore, but the 16N3-1 can also be used for the S51.
0 x
Benutzeravatar
Fussel-Fuchs
Simson-Kenner
Simson-Kenner
x 130
x 198
#5 Beitrag von Fussel-Fuchs » 17 Mär 2018, 09:12
Wasn't the best carburetor, it needed an in mechanical perfect conditioned engine.
It was very sensitive for every change in the system.
Be sure that your carburetor is really clean and check your gasket to the cylinder.
Replace the shaft seals if needed, they're often out of lifetime after 30 years.
0 x
Antworten
Wer ist online?
Mitglieder in diesem Forum: Bing [Bot] und 4 Gäste
