Timing marks for a kr51/1
tommi123
x 10
Re: Timing marks for a kr51/1
#11 Beitrag von tommi123 » 24 Okt 2018, 17:04
Thanks its got a good ground to 31 but when i test for voltage i get 6v from the switch body .this cannot be right as the switch is attached to the bodywork wich is a ground .the switch is brand new ?
Herr Ingenieur
x 30
#12 Beitrag von Herr Ingenieur » 24 Okt 2018, 17:19
Then put the battery of an start your engine again. But normally the battery has nothing to do with the ignition.
"TRT - Tequila Racing Team" - Sprintrennveranstalter
Am Öl kanns nicht liegen - war keins drin... :ph34r:
tommi123
x 10
#13 Beitrag von tommi123 » 24 Okt 2018, 17:35
The batery as been in place all the time i still get a 6 volt reading from the switch body when the engine is not running but no power to the light switch or the infocators could it be a inferior switch it came from AKF .i have had problems when restoring japaneze bikes with chinece parts
Herr Ingenieur
x 30
#14 Beitrag von Herr Ingenieur » 24 Okt 2018, 17:52
Try to read the wiring diagramm find the mistake at your wiring harness.
Riffor
x 35
x 34
#15 Beitrag von Riffor » 24 Okt 2018, 17:58
Please figure out if you have not mistaken the numbers on the switch up/down, it's a bit confusing. Try to search for a single wiring point and you can see if you have wired it the right way
tommi123
x 10
#16 Beitrag von tommi123 » 24 Okt 2018, 18:12
Thanks for the advice will check again tommorow i will renstate the original switch but its to cold in the garage in falkenein right now tome for a glass of wine .Thanks for your advice i have made good progress today .have a good evening Tommi
