Beiträge von khaldrogo
    Finding the right coolers or ice chests for your camping trips or game-day parties might make you feel overwhelmed, but now you are in the right place. These days, we are looking for not only coolers that have rich features, but also those that are good for many different purposes. For example, a small cooler for just packing a lunch when going to the park and also for personal use.
    However, sometimes, if you need a larger cooler for a group of people or for your family, the medium-sized cooler will be better. And in other scenarios, you may look for coolers which can handle bulky work. Whatever factors you are looking for in a cooler, lets go to the next part and we will show you the best coolers.
    1. Yeti Tundra 65 Cooler - Best overall
    Specifications
    Dimensions: 30.5 x 17.5 x 16 inches
    Weight: 29 pounds
    Capacity: 52 quarts
    The Yeti brand is well-known with high-quality cooler lines, and the Yeti Tundra 65 is one of our top picks for overall performance. With a sturdy construction, the Tundra 65 can keep things very cold for a long time. Great insulation thanks to extra-thick wall design and also pressure-injected foam in the walls make sure that the cooler is armored to the core.
    Its lid latches are constructed of heavy-duty rubber, and all things that offer high durability. Although the price is a little bit high, it is worth investing in it for many camping trips. That why this cooler features in the list of top rated coolers for camping by many users and cooler experts. However, you should know this cooler is not light and also with no wheels included, sometimes it might be bulky to carry or take on a hike.
    2. Coleman Performance Portable Cooler, 48 Quart - The runner-up
    Specifications
    Dimensions: 24.9 x 13.9 x 13.6 inches
    Weight: 7.2 pounds
    Capacity: 48 quarts
    This is a classic portable hard-shelled cooler. With the rugged and leak-resistant design, the Coleman Performance portable cooler can provide ice retention for multiple days. You can be sure to keep your food hot and drinks cold in outdoor barbecues and camping trips. This cooler can hold up to 63 cans and is also tall enough to accommodate a two-liter bottle stand. This portable cooler by Coleman is also appreciated for its durability if you use it properly and spend a little time to wipe it clean. Moreover, the price couldn't be better.
    However, some people faced and issues and reported that its lid is prone to break easily so if you are going to own the one, notice all the negative aspects about this product when using it.
    3. Coleman FlipLid Personal Cooler - Best small cooler
    Specifications
    Dimensions: 8.1 x 7.2 x 10.7 inches
    Shipping Weight: 1.54 pounds
    Capacity: Holds up to 6 cans
    Why is the Coleman 5 Quart FlipLid Cooler our pick for one of the best small coolers in the market? This cooler will amaze you with its features although it is so small. Firstly, it can turn into a mini table. Just open the cooler, flip its lid over and get ready to eat right on the cooler.
    The Coleman 5 Quart FlipLid is very portable, and you can carry it just with one hand and use the other one to pack your lunch. The bail handle helps you carry it easily. The cooler is large enough to holp up to 6 cans and keep things cold. Besides, the EZ-Clean lid is designed with a smoother texture to allow you to wipe it clean easily after using it.
    Sad to say, but there are several complaints about this cooler. Customers said that this cooler lacks insulation. Also, its lid and handle is not as durable as they originally expected. However, this cooler still makes it to the list of best rated coolers on the market because it enjoys a large following of trusted users. This is really one of the good small coolers worth for money.
    RELATED: https://thekinglive.com/best-coolers-and-ice-chests.html
    4. Igloo Ice Cube Roller Cooler (60-Quart, Ocean Blue) - Best Medium sized cooler
    Specifications
    Dimensions: 18.5 x 20.3 x 20.5 inches
    Weight: 12.2 pounds
    Capacity: 60 quarts
    The Igloo ice cube roller cooler is one of the great medium sized coolers that can deliver 60 quarts of capacity. The “Ultratherm” insulated body is ideal for keeping things inside cold in a long time. Although it isn't small in size, this cooler is still very easy to transport thanks to its construction. There are wheeled options for easy transport and also be used to push or pull.
    There are the molded-in side handles for loading and unloading easily. Aside from that, Igloo ice cube roller cooler is easy to clean by baking soda and water, then you don’t have to worry about stains and odors.
    However, the handle of this cooler is not very durable and the cooling time might be not good as the manufacturer advertises. So, you should think carefully before buying it. But, we think with at this cooler price, it's hard to find the better one.
    5. Lifetime 55-Quart High Performance Cooler, Grey, 90820 - Best cooler for the money
    Specifications
    Dimensions: 27 x 17.6 x 17.3 inches
    Weight: 23.4 pounds
    Capacity: 55 quarts
    After doing some tests of coolers from 28 quarts to 77 quarts, we see the Lifetime 55 Quart high performance cooler has some really impressive at an affordable price. This cooler offers superior performance which can deliver up to 7-day ice retention.
    Also, the foam-filled lid offers longer cold retention. Besides that, the hinge rod is made from stainless steel and cooler is constructed from heavy-duty polyethylene. All these factors make the cooler more durable. Our only complaint with the Lifetime 55 Quart cooler is that the lid isn’t very sturdy and it doesn’t have wheels. However, it still is one of the best coolers for the money.
    Final thoughts
    Have you found a winner out of our best ice cooler reviews for your own? One cooler can be the best cooler for somebody but not for the others. However, in thousands of coolers on the market, to avoid spending much of your time and effort, it's best to read cooler reviews from cooler experts and users. We hope this article can simplify your buying process and will be happy to help if you have any questions about coolers.
