50cc Racing cylinder water cooled conversion with single combustion chamber
Looking for a 50cc racing cylinder for Simson? You are right! This cylinder conversion is based on experience in the Simson Challenge. Is precisely this cylinder could be consistently won the championship from 2005-2008. The cylinder is a very good performance levels and extreme reliability. The cylinder has a 5 channel flush and a 3-piece outlet. It was welded to the cylinder, a water jacket (aluminum). The cylinder is supplied with a one piston ring and a separate combustion chamber and a cover for the water, a usage Brennraum.Es capable GDR cylinder to be sent. Where the condition of the liner does not matter anyway because a new one is installed it, so the cylinder is delivered in zero dimension (38mm bore). The processing time is 3-4 weeks. Included: Cylinder (water cooled), piston ring, pin and clips, combustion chamber, water cover for combustion chamber with o-rings and gasket.
so what do you mean?
Kulle
